SS MAYFLOAT
Thread starter- Joined
- May 17, 2001
- 6,372
My BIL just stopped by to have me drive his truck. When I got to about 40, I could feel a vibration coming from the rear of the truck. The faster I went the more violent the vibration was. I told him that I think either the universals are going, driveshaft bent, or it lost a balance weight.
We got back to the house and I checked the rims to see any fresh marks of a wheel weight being throwed off. None, they were all in tact. Crawled underneath and did the test for loose universals. Nice and tight and no play in the carrier bearing. I had him put the truck in neutral and moved the truck to rotate the drive shaft. On the front drive shaft, there is a fresh mark about 4"long, 3/4 inch wide where a balancing weight could have been. It is the only fresh mark on it as the rest of it is rusty from many years of winter salt.
He said he wants to get rid of the truck and not worried about it. I told him that it will tear up the rear tailshaft bearing in the tranny and eventually the seal will start leaking. I suggested taking a 4" long bolt, 3/8" dia, and saw the head off it. Then take two radiator hose clamps and clamp it in place. If it is too much weight, then use a 5/16" bolt or saw off a half inch at a time of the 3/8. I've done this before and while it is not perfect, it helps a bunch until a driveshaft is obtained.
Just checking to see if anyone else has a quick fix for a driveshaft that has thrown a balancing weight......Thanks,,,,,,,,,,SS
