I have a 9.8 hp merc (SN 5640813). When I adjust the large handle the whole way (either in forward or reverse), the throttle linkage moves very little. I have adjusted the barrel nut all the way to the end of the threaded part of the linkage, and it is still opening the throttle only about half way. The motor will not move any faster than throttle speed in reverse. I am not sure if I have to adjust something (and what to adjust) or if I need a new throttle cable.
If I take the cover off and move the spark advance by hand, it will hit the stop screw and the motor puts out the power I would expect. As it is now, however, when the throttle controll is fully opened, the spark advance arm is about 1/4" away from the stop screw and it barely pushes my 16 foot sea nymph (I would estimate 5 mph at the very most).
Any suggestions would be helpful.
