1964 johnson 40 oil in water pump and no fwd
eriklane
Redid the LU seals, but couldn't find where some of them in the kit went to...put it all back together and yet when I ran it, with a hose in the water inlet, it isn't pumping. Does the water pump rely on those 6 small drilled holes to pull in water? If so, what is the screen on the passenger side of the motor for(about 2" long x 3/4" tall)? And where EXACTLY does the water get INTO the water pump/impeller? I don't see where it goes in.
Thanks
F_R
Re: 1964 johnson 40 oil in water pump and no fwd
You can't run a 40 on a hose unless you have the Tempo Flushette adapter, which is pretty rare.
The water intake is the screen on the leading edge of the exhaust snout above/rearward of the propeller. Shoving a water hose up the exhaust is a great way to fill the cylinders with water and damage the bearings if you don't get it out of there.
