Firemedic09
Thread starter- Joined
- Jul 1, 2008
- 46
I just bought a 1986 Bayliner Capri with a Force 125hp motor. and i checked the fluids and everything and lubricated everything that needed to be. and checked the fluids etc. juts the general stuff that's supposed to be done.
Before i went out this morning i filled it up with 87 and mixed the oil with it just like your supposed to and added some lead substitute as the manual said to the mixture it was also supposed to be.
I took the boat out for the first time today and it had a little trouble starting. no big deal after a few rounds with the choke it finally fired and idled just fine.
After i got away from the dock and out of the no wake zone i figured it was warmed up enough and i would open up the throttle and see what it had...
Well i slowly pushed the accelerator forward and to my surprise... it dies. so i restart it put around a little and decide to try it again..it dies. so i restart it one more time and SLOWLY(like a snail) ease into it and it speeds up to a fast paced rate of 15 mph! that was maxed out. and it soon started to crap out and sputter so i back down the throttle back to neutral wait a minute try it again and it is soon doing the same problem. So i figured i would just putt around. try my luck at fishing or swimming or something. didn't want to waste the day.
Well then i put it in neutral shut off the engine and swam around. a while later i started to go back to the marina/dock. to my surprise it wouldn't go into the forward gear. to explain the situation a little better i will give you blow by blow. started engine, let it idle a minute, pushed throttle forward, started to rev it up. wasnt going anywhere so i stopped checked everything nothing cought on the prop. tried it again still same problem. would rev up but wasnt in the forward gear. and if i left it revved up for to long it would eventually catch the gear and with a loud thump would start going forward and stop again as fast as it started. after one round of this i shut off the engine got in the water and inspected more closely, after finding nothing i decided that unfortunately i would paddle the boat back to the dock. after 10 seconds of getting nowhere because of the waves i started it up again. this time trying reverse, worked great and there was power in that gear too! seemed like the engine was going to rip off the transom! 10x the power of forward! after slowing down to a good pace and knowing it wasn't going to do the same as the forward gear i revered all the way back to the dock. what a long ride. so pulled it out of the water on the trailer brought it home, was looking at it and had told my wife to put the throttle into forward(key off, battery off, engine not running) and i spun the prop around by hand and could hear a clicking sound. i then asked her to do this in the reverse part of the throttle. and i couldn't turn it with ease like i could in the forward position. could this explain the lack of power all the way around? or is the lack of power with the engine separate from not being able to go forward. i forgot to mention that with the engine in neutral it seemed like it would rev up fine to a high idle, along with a better response. not that i was redlining it so dont think that.
also i think this might be a fluid issue but the tilt/trim slowly leaks down. i have checked for leaks and there isnt any. just seems like the fluid slowly finds its way back to the reservoir. what would i need to fix this to be stable again(what parts)
