baw3510maverick
Thread starter- Joined
- Jul 2, 2008
- 16
Background:
I bought an '86 Chris Craft 2 years ago, and have continued to try to run down a couple of problems. After rebuilding the carb, the engine was still bogging down at full throttle, and would intermittently sputter and backfire.
Last year, I threw my hands up and had a guy look at it. He diagnosed "no advance signal, bad distributor and ignition modual"-i've now duly noted the mispelling of module.
He removed the thunderbolt ignition amplifier, replaced the OEM distributor with an HEI distributor (not sure what kind of pickup--still getting schooled on ignition systems) and somehow wired it straight into the wiring harness.
The boat was run 1 time after the repair, and I had to run it in circles for about 30 minutes, and it finally evened out and ran for a couple of hours, but wasn't quite right. Thought it was coincidentally bad gas.
This year--March I drug my boat from home in Alabama, to Maryland, where I'm stationed in the Marines, and began getting it prepared for the season.
After de-winterizing, I cranked her up and ran her at idle for a good hour. Shut her down--no problems. The next day I was going to take her to the water, and I could not get it to start, finally got it started but couldnt keep it running.
Found another "marine mechanic" to come have a look. He got the boat to crank and run some, then it would not start again. He determined it was jumping time, needed a new timing chain; then we could not get the motor to stay running at all. I said great, never heard from the guy again.
Got a mechanic buddy from work that "knows boats" to have a look, and to my disbelief, it cranked right up. Remember the last time it was being cranked--it wouldn't run. He adjusted the distributor, and we kept it idling, but it had major backfire when gouging the throttle. It also was missing really bad. All new plugs and wires, fire on all. We found that there was no advance on the timing, and it did not seem to be jumping time. We determined that without the amplifier, there could be no advance.
We then found out Mercruiser does not manufacture the amplifier any longer.
I orderd an MSD iginition kit, under the impression from talking to the tech, that this would solve my problem and replace the OEM system.
Upon receiving the kit, I found the wiring diagram calls for the ignition control module to be plugged into the OEM Ignition Amplifier!
Back to square one!
1986 Merc 200 Alpha I, SN A482092
Ignition Amplifier, P/N 390-7804A3, is not available from Mercruiser or any used parts dealer I could find.
Finally the question:
1- If this part is unavailable what is the work around? Mercruiser couldn't tell me. I was astounded there was no superceding part or a fix.
2- Does anyone have any idea where to find an aftermarket or used amplifier?
This issue has had to have been experienced by others. I've read all the Thunderbolt and Mercruiser threads till I cried, but couldn't find anyone specifically addressing the parts problem.
Final note: I apologize for the length of the post, but after reading about 100 the past week, I've seen quite a bit of chastisement from you guys on people not providing enough info. So hopefully the overkill doesn't kill you.
Thanks,
Brett
Back to square one!
Thanks,
Brett
