MossyOak99
Thread starter- Joined
- Aug 18, 2006
- 25
I replaced the water pump in my lower unit today. It is a 87 alpha one going into a Mercruiser 120. I had no problems with any of the work. However, it doesn't seem to go into reverse now. I did this with the outdrive on the boat and and made sure to put the control in forward. I also put the lower unit in drive by turning the shift selector clockwise and then held prop shaft counterclockwise while putting back together. I am sure that it did not slip out of gear. Did the spin the prop check and spins freely in reverse, locks counter-clockwise and clicks clockwise in forward, but clicks in both directions in reverse. I don't know what may be causing this. Any help would be appreciated. Could it be that somehow the shift shaft didn't line up correctly even though it was in reverse?
