Reverse problems.
MossyOak99
I replaced the water pump in my lower unit today. It is a 87 alpha one going into a Mercruiser 120. I had no problems with any of the work. However, it doesn't seem to go into reverse now. I did this with the outdrive on the boat and and made sure to put the control in forward. I also put the lower unit in drive by turning the shift selector clockwise and then held prop shaft counterclockwise while putting back together. I am sure that it did not slip out of gear. Did the spin the prop check and spins freely in reverse, locks counter-clockwise and clicks clockwise in forward, but clicks in both directions in reverse. I don't know what may be causing this. Any help would be appreciated. Could it be that somehow the shift shaft didn't line up correctly even though it was in reverse?
Don S
Re: Reverse problems.
Raise the drive up and see if the shift shafts are together properly.
MossyOak99
Thanks for the quick reply. Went out and checked it. All is lined up properly. With control unit in reverse it is close to catching, when i put just a little extra pressure on the shift shafts in locks right in. Could this be a simple cable adjustment? If so how would I go about doing that?
MossyOak99
Thanks Don. That should finish up this part of the project. I appreciate your help with this.
