1995 60hp mariner beeping
joed
Gassed up last Sunday. had ignition ON to watch gas gauge. Forgot and left ignition on all week. Came back today and boat was beeping away.
It is continuous beeeeeeeeeeeeeeeeeeeep not beep beep beep.
Disconnected two blue wire from oil tank - continued.
Disconnected tan/blue wire from sensor on head (temp I think) - continued.
Disconnected tan/blue wire that appears to go into ignition block and beep stopped.
Saturday when I can get some time what should I check?
Thanks.
joed
Re: 1995 60hp mariner beeping
Testing seems to indicate the problem is the warning module according the Clymer manual I have.
woody66912
leave all wires hooked up take coat hanger bend straight out with 1/2 L bend at end try to hook oil float in oil tank pull float up note this test is key on if horn shuts off need to install new tank horn stays on replace oil warring module
joed
Doesn't disconnecting the two blue wires do the same test?
Called the dealer. 121.70 + tax. He can order Monday and have Tuesday or Wednesday.
joed
Does anyone have a the ohm reading I should get from the warning module? I would like to try and confirm problem before ordering part.
Also, is dealer only source of this part? Any good online stores in Canada. I could not find part listed here on iboats.
woody66912
joed iv'e been burnt on this one too many times .there is no ohms reading .the best i can figure is module goes to a default mode when oil switch is unpluged I keep a knowen good module in my tool box. it is very comin for the oil float to get saturated with oil my way of testing this is you have to admit is free.
joed
What about the oil switch? Can I ohm that?
cannonford57
sounds like module...rapair electronics.....quality stuff
woody66912
yes you can it should show 0.2 to0.0 ohms .
woody66912
joed stick with it how ever you want test. is up to you butt remember some us us old guys can still help. stick with it.
joed
The module has been replaced and all is well.
Some notes that may help others.
With the blue wires disconnected there is no beeping.
If you short the blue wires it simulates low oil and beep beep beep etc.
The blue wires from the tank measure open if the oil tank sensor is working and there is oil in the tank.
