Johnson 112spl
Bullit
I have a 95 112 spl and started having some problems . 1st is that it has gotten harder to start and once started it runs fine but after i run it for about 30 mins and put back to idle for a few mins it wants to die and then i give it the gas and it wants to just barely move rpms stay low along with the speed, and after a few mins of this i drop it down towards idle and then give it gas it will take off has normal. Changed the Fuel filters and ran great, started good and then after about an hour started acting up. Any suggestions would be much appreciated.
mrdad990
Mine is having same issue… did you ever get it figured out?
saltchuckmatt
Mrdad, you followed a post from 2010 and then a post from 2008. Start a new post, state your outboard year, size and model number, then explain what it is doing and someone can then try to advise you. Sounds like your having a idle issue and that's past my pay grade most likely. Lots of folks here can help.
