140 engine problem
first time owner
i have 85 140 gm block is leaking water from lifter/pushrod cover on engine. any suggestions would be great.
Fishermark
Re: 140 engine problem
If you have water coming from there, then you have water in the oil. Pull the dipstick - is the oil milky?
chiefalen
You have water leaking from the side of the motor starboard side pushrod cover? Or the valve cover top of the motor?
first time owner
theres no water in oil checked dipstick and oil was low a quart but no water
Ayuh,....
The Only thing behind that Cover, is the Oil cavity...
It Can't leak Water....
Matter of fact,... That whole side of the Block is Dry.....
Must be dripping down from the Head.....
first time owner
maybe blown head gasket or cracked head only does leak when in water not when on muffs
