140 engine problem
Fishermark
Re: 140 engine problem
If you have water coming from there, then you have water in the oil. Pull the dipstick - is the oil milky?
chiefalen
You have water leaking from the side of the motor starboard side pushrod cover? Or the valve cover top of the motor?
Ayuh,....
The Only thing behind that Cover, is the Oil cavity...
It Can't leak Water....
Matter of fact,... That whole side of the Block is Dry.....
Must be dripping down from the Head.....
