Re: riser/mainifold replacement cost
You need to determine if you have wet or dry joint exhaust. Dry joint (2004 and later) is not available from any aftermarket sources as far as I know. Merc OEM dry joint lists around $1,300 plus install. If you need a riser kit, add another $500.00. This will seem cheap when you see the price of the new catalyst exhaust system.
