Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
I installed the Red Eye Bearing Buddy system in my trailer. This is the 1.9 size hub. The problem I have is that the cutter pin dug a trench in the bearing buddy. Is that normal? I would think not. I used a cutter pin that the round part fits inside of the spindle nut cuts and I bent the other side as close as I could and even bent the ends inside the nut cuts. I don't know what else could I have done. In my previous post I wrote where I found part of another bearing buddy system in the hub. I wonder if that is what also happened to that other system.
http://forums.iboats.com/showthread.php?t=265571
Let me know if any of you have run into this...
Thanks!
Thanks!
