1981 70hp Johnson Kill switch install
jedimaster
So, I am gong to be installing an aftermarket kill switch does anyone know what wre it should be hooked up to or what the wiring is? I would assume you just cut and splice the kill switch into one of the ignition wires....
Thanks.
ftltony
Re: 1981 70hp Johnson Kill switch install
Didn't it come with directions?
ezeke
The kill switch will ground your powerpack the same way that turning the key to off does; by closing the ignition gound to the black and yellow kill wire circuit. See the following link for excellent diagrams [scroll down]: http://continuouswave.com/whaler/reference/ignitionSwitch.html
Be careful to disconnect your battery before wiring the switch. Any voltage riding that black and yellow wire can instantly kill your powerpack.
