wmgraphics
Thread starter- Joined
- Jun 30, 2008
- 47
Re: 73 115hp starting problems
Well I got the LU up and flush. Started her up and vooom.. good. I shifted it into gear and prop spun. Now, the pee hole is either just barely squirting water out on the right side (looking at the motor from the front) and a constant dribbling out on the left. I increased the engine throttle while in gear by hand and it didn't really change much. Although, once I shut off the motor it started peeing just fine and eventually ran out. Did I put the impeller on backwards? I thought I put it on right. The original impeller was badly damaged and was missing chunks and wings. Do you think that some of these bits of impeller are lodged up in the cooling system somewhere? Or maybe that last 1/4 inch on the LU to flush install damaged one of the water tubes?
Thanks for all your help by the way!
