novice boater54
Thread starter- Joined
- Jul 20, 2008
- 42
I just purchased an 85 HP jonson outboard. I wasn't able to hear it running.
I have the controls that went with it. I mounted it on my boat and while using a flush attachement and the lower end in a container of water I was able to get this unit to fire and run for several minutes and after it died I noticed that the engine was a little warm. I had to activate the starter at the solenoid to actuate the throttle to keep it running as I haven't mounted the key switch and the controls yet. My problem is that the engine will seemingly only fire or kick when releasing the starter engagement and at the same time moving the lever where the throttle attaches to.I observed this whille having a plug removed to observe spark and while cranking there didn't appear to be any spark until releasing the solenoid.
I never fiddled with the adjustments of anything on the motor (yet) but not this motor won't run only kick once in a while. I also had the motor kick and fire while bumping the stater and now it seems the saterter shaft was bent in this exercise and now I have to replce the starter.
The motor has been converted over to breakerless igniotion by someone with a bombardier ignition module. I have a manual on order but until I have something to read I'm at odds to determine the cause of the hard starting or any adjustments. I was told before I bought the motor that it had 140lbs compression. Is that good. Since I had it running I took my own readings and they were quite different more like 100lbs on #1, 2 & 4 and 95lbs on #3.
Could the problem be a timing issue and how does one adjust the timing?
I have since replaced the water pump impeller.
I had difficultis in aligning the water tubes as it seems that someone had managed to magle the one end of the copper tube. I attempted to reshape it to work with the guide. Whe reassembling it I hope I got the damaged one inserted correctly. I haven't had it running since the starter was damaged. I also noted that when moving the lever that is connected to the trunuion back and forth it would attempt to fire the engine by obviously actiavting the ignition system simlar to starting.
In addition is there two serial numbers on a motor one for the power head and one for the lower end or main unit as I suspect this motor may have been rebuilt ot switched?
Hopefully someone can help with this.
Thanks so much
Thanks so much
