novice boater54
Thread starter- Joined
- Jul 20, 2008
- 42
Re: engine electrical
Hi Joe. it's ok my fingers do the same thing and then I don't proof read my material when I hit send key, lol.
Ok regarding the rectifier situation I presume from what you are saying that it doesn't even have to be hooked up.
On the same topic does the rectifier affect ignition as indicated in my seloc manual, as it indicates that if the rectifier is faulty the starter will operate but ignition will not occur, is this true?
I have looked at the prices here on i-boat for the rectifier and theyr'e wuite reasonable here may order through here.
I guess as I said the next test will be the pulse pack test to determine if there is failure there.
By the way the color of the paint is a green colour so I'm presuming it's Johnson colours. It has been indicated to me that a lot of parts can be subsititued between manufacturers and models so I wouldn't really know what had or hadn't been subsitituted. I had been told by an unscrupulous marine repair shop that when I ordered an exhaust gasket for the lower end that my lower end must have been switched as the gasket received was nothing close to the one I had and I even had the lower end with me when ordering the parts. This individual didn't choose to compare pictures in his parts book and exclusiviely went by part number trying to tell me that this lower end must have been changed.
I'll let you know the results of the pulse pack test.
Thanks again
Regards
Ron
Thanks again
Regards
Ron
