I've finally saved up enough money (built up a large enough line of credit on my cards?) to undertake the restoration of my boat. It is a 1981 Sea Nymph model JB-161. This boat has a lot of meaning to me, as it's the one my grandfather bought in 1981 and the one in which I caught my first fish. I had it running about 8 years ago - it had sat in a barn for the previous 10 and had mouse nests in the motor, wires had been chewed through, etc. It sat outside for a winter, while I was at basic training, filled with water and then froze into a solid block. So far, I have stripped out all of the carpet except the part that is held down by a riveted aluminum frame and have removed all of the rotted wood. The two main deck pieces are still in good shape, despite the years of torture, and I have coated them with a water sealant. I've been searching for a carpet kit, but it doesn't look like anyone makes one. I have saved all of the carpet I've removed so I can make a pattern if needed. I've never undertaken a project quite this big, but I have half of August and half of September off, so I think I should have enough time to get most of it done. What type of wood should I use to replace the pieces I've removed? The old carpet was glued in and then held in place with screws - should I use this same method? I would really appreciate any help and guidance anyone can give me.
Matt
Matt
