new to boating need help
my_bigmike
hello to all i just bought a boat and i have a couple of qustines i have a 1995 sea ray 200 it needed and engine so i put a car engine in it someone told me that it wouldnt hold up becouse of the high rpms is any of this true? and under the blower ther is a hole does it need a plug or something becouse some one told me it did and another guy said that this boat didnt becouse it have a pump in it? thanks
mtnrat
Re: new to boating need help
What engine (year, displacement, carb-EFI ?), and from what type of car?
JustJason
a car engine will not work unless the block has been stripped down and fully marinized.
Ayuh,...
Welcome Aboard Mike,...
If you could explain the Hole your talking about, along with Exactly what motor,+ drive you've got,..
I'm sure We can answer your Questions...
my_bigmike
hello tell all and thank u for the replays the engine is a 5.7 i took it off of a 1994 gmc yukon i couldnt get the fuel inj to work so we made it carb i got the engine working but someone told me that it wouldnt last long becouse its not made to hold high rpm unlike the boat engine it can hold high rpm and on the holes on the boat thers three i know the drain plug needs to be ther so thers another 2 one on each side dont realy know anything about them ? i hope i dont have to sell this boat becouse i put alot of work into it but if the engine isnt going to last long i guss id sell it and buy a new one
Limited-Time
A pic would help for the holes...........................and a little punctuation would co a long way in your post......................;);)
Ayuh,....
Basically,.. That motor should be Just Fine.....
GM truck motors are almost exactly the same as production Boat motors.....
So,... What's the Drive,..??
Btw,...
I donno what your hull's Holes are for,....
But,... They definitely need to be Plugged...
my_bigmike
thanks u for ur help the holes ther is one on each side they dont look like they need to be pluged but then again i dont know anything about boats i think theu might be for the water pump i well try to post some pic
bolo78910
oh boy , u better post some pic, seems u dont have a clue about boats, dont feel bad. u will gets help here, and as bondo said that engine should be fine, you r going to have to change a few things, to get it marineise, good luck.
superpop
Did you happen to change the Carb, Starter, Alt, Ignition, and Fuel System to marine version. Hopefully you were able to use these parts from the old motor. Otherwise they will need to be changed. Or the boat could go boom.
Uraijit
Banned
The only thing you really need to change on the engine is the freeze plugs (should be brass), and make sure the head gaskets are non-metalic.
Do that, and the engine will last as long as the hull, if you maintain it properly.
Your truck cam should be fine for boating. If you have problems, you can change it out for a marine cam for about $150 or so.
As was already mentioned, make sure the starter, alternator, distributor, carb, and fuel pump are marine parts. These are a must, as they're a huge safety issue.
The water pump also won't last long if it's not a marine pump.
my_bigmike
thanks to all im starting to lern more about the boat im not going to take it to water untill i know everything i need to know about boating as for the engine i changed everything but the carb mine didnt have a carb it was fuel injec but ther was something wroung whith the fuel injec it didnt work so i just changed it to carb whats the diffrernce betwen the car and the boat carb?again i lernd alot from u guys thank u
Ayuh,...
Marine Carbs are designed to leak into the motor.....
Automotive Carbs will Leak into the Bilge.....
If it should Leak at All that is.... Another Safety Feature....... ;)
my_bigmike
so u dont think the car carb would work and what kinda of riskes are we talking about her becouse i started the engine it sounded alright u think its not going to make it whith thats carb? it and the distr are the only 2 things that i used from the car and one more qustine how fast is crusing speed in this boat ? again thank u bond u been a great help
Ayuh,....
How about This,...
or This,....
littlebookworm
Hi, Mike. Welcome to the forum. Try to relax a little; you sound very anxious and there's no need to be. So far, you're doing pretty well. You do need to replace the carb and distributor with marine versions to eliminate the possibility of an explosion or fire. For help with the"holes" you keep mentioning, photos are needed. You should also get yourself a Mercruiser service manual for the engine you have. It will make maintenance and repairs alot easier. As you've been told, boat engines and truck engines are basically the same. Boat engine use brass "freeze-out" plugs and stainless steel or non-metallic head gaskets (eliminates rust). Those should be changed. Any other questions you've got will be answered here. So relax and enjoy getting your boat ready. Safe boating. Hy
APPALOOSA2
I hope you used the exhaust manifolds that were on the original engine in the boat, they are water cooled !
imported_TheMan
Maybe you have thru hull exhaust and they are your other holes? Again, pictures would be invaluable in helping you..
my_bigmike
thanks to all of you guys you guys been great help but i mad my mind im going to sell this boat i dont whant to go out in the water and be worried all the time about this or that or the carb so i think ill just sell it thanks again
my_bigmike
well i took my boat out to the lake yestrday test drive before i sell and i tell u i was going 55 miles like nothing and thats whith a 77camaro carb and distr so i took it out for about 3 hours or so runs good so i think im going to keep it just to let every one know the carb and distr cab are great even thou that they arent marine i had no problom what so ever ill keep u guys updated
