jp89bayliner
Thread starter- Joined
- Jun 11, 2008
- 52
well I finally got my fuel system working correctly. But I have a question about my quadrajet of my 1985 omc. The motor is a 305 with a 4 bbl quadrajet. I pulled the carb apart to do a rebuild first time. It went well and was not that hard to do as I thought. My question is that I rebuilt it becuase when I go to wot from a slow speed it falls on it's face for a few monents then picks up and goes to top speed. I thought my rebuild would take care of it but it did not still there. My question is I found a great tech artical on the quadrajet and while I was reading it and looking at the pics I saw were they were talking about power valve springs and how you can change them to flow more fuel. When I had mine apart I did not see any spring under the power valve? I wonder if some one has been in the carb before or due marine carbs not have them? I think that would explain my bog when going to wot. Am I correct in thinking this.
When I rebuilt the carb I soaked the carb in carb dip over night, checked all surfaces were flat and they werent so I took it to the machine shop and they made all the mounting surfaces flat. I then replaced all parts that came in my kit including a new brass float set to correct level.
I also noticed that in the tech articale that I read that they epoxy all the plugs cause they are known to leak fuel from the bowl. I did not do this and that would probley explain why when it sits off for awile that when it starts It is hard to start that I haft to wait for the bowl to fill up before it will start. I know this because while I was at the carb after the boat was off for some time I had friend pump the throttle I heard air coming from the accelerator pump but no fuel until you crank the engine and gas fills the bowl.
Any pros got some tips I would really appreciate them, and also were can I get a power valve spring from what I read they are calibrated for each aplacation Thank's for any help in advanced.
