jp89bayliner
- Joined
- Jun 11, 2008
- 52
Re: carb question.
I am postive there is no power valve spring under the power valve. I should of known better when I took the carb apart and was looking at the diagram of the carb when I was putting it togather. But I did not know. Like I said first time every working on a QJ. I feel real dumb at this point but I guess I will live and learn. I guess when I was working on it
I was thinking when I put it togather that spring should probley be there , but I thought maybee marine carbs don't have that. The guy at napa looked up the part and crossed the number into a napa rebuild kit. I thought that it was for a auto carb, but the guy told me they were the same. So looking at the diagram I figured that was there because it coverd auto too. My dumb mistake.
Also yes I am sure the metering rod's are there but your story sounds pretty funny though.
Wait, do you have the 2 metering rods #7 in the Pic.??? I did not think the engine would run without a power valve spring?Are you sure it's not there?
This I gotta see? You've gotta figure the metering rods are being sucked down by vacuum, closing off the main jets with no spring to hold them open. If this is the case, please don't mess with anything else on the carb till you get this done, & try it! If this is as you say, I'd bet it's your only problem.
Many, yrs ago, when I was much younger, I was looking for performance, and I removed the primary metering rods from my Qjet, leaving the jets wide open
Big Mistake! The car ran, but a total bog, with black smoke out the exhaust, and I could see the gas gauge go down, as I drove it! It was the opposite of what you have, running Way too Rich! I couldn't get the metering rods back in fast enough, and decided not to try that again :redface:
