push button shift/TOGGLE SWITCH UPDATE SOLVED THANKS FR
tx1961whaler
Re: push button shift/TOGGLE SWITCH UPDATE SOLVED THANKS FR
I had something like this on mine:
bigpoppakdog
sea-way did indeed have the part, but wanted $200.00 I thought it was made out of crude oil for a second.:rolleyes:
jay_merrill
Given the difficulty in finding the part you need, $200 is a bargain. I just bought a serviceable 1972 Johnson (hydroelectric shift) for $150 just because the shift switch in the owner's control unit went bad.
If you buy a control unit from craigslist, ebay, etc., make sure it is the correct one because the selectric shift units and the hydroelectric shift units are not the same.
bigpoppakdog
i went with the toggle method without reverse hooked up. I have yet to use reverse where I wakeboard because there is no current.
jay_merrill
K - I guess I am assuming that your motor is a hydroelectric shift. If so, you might want to keep an eye out in the classifieds and auction sites for a control unit with a yellow plug on the engine end of the wiring harness. Evinrude or Johnson (the Johnson works via a shift switch which is tripped by the throttle/shift lever) will work.
As others have said, used parts are a gamble but the risk is the same as if the control unit came with the motor - a control unit from either source is old and you have to ask questions before you buy.
Bigjohnwayne
Ok i need help with this toggle switch, I have two white wires and also have the blue, green and the multie colored wire what to i need to wire this up?
The switch is as follows with the wires.
-white -white
-multi -Blue
-Green
The multi color wire has a jumper fro the multi to an open next to the green.
Can anyone tell me how to wire this to a toggle switch Please help!!!!!!!!!!!!!!!
