prime
dcata
I got a 1993 Johnson 115hp I took off one boat and put on mine and hook it up the same as the other boat. The motor will start and run, but Im having a problem with the prime. The primer bulb never gets rock hard and the motor will die after about 3-4 minutes at idle. I have put all new fuel line from the tank to water seperator to the engine with a new primer bulb. Im very open to any suggestions to what could be wrong. Thanks
kenmyfam
Re: prime
Air leak in the system or failing fuel pump comes to mind. Take fuel feed line to the carbs off and crank into a gas container. See if it keeps a steady flow. If it starts out good and tails off it is most likely the pump.
Having said that you must make certain that the system is not drawing air.
