Re: linkage and idling problem '76 evinrude 85 hp
Welcome to iboats.
I agree with above ^^^ get yourself a factory OEM Service Manual. It WILL pay for itself a million times over.
Sounds like you have a couple problems here. First off, the starting issue. Either your battery is faulty (take it into a Canadian Tire and have them load test it for you, its free), OR there is a faulty section of wiring OR a bad connection. This includes at the battery, starter, solenoid, and engine ground. Take them all off, file them up, then re tighten. Look for faulty sections of wiring. Any wiring with nicks, cuts, abrasions will need to be replaced. "Crunching" when you flex it is also a sure sign of inner corrosion. Voltage drop testing is a quick and easy way to find a faulty segment of wiring, or faulty component. Let us know if you need help with this.
Regarding the idle, may be a couple things. Is it set to 650 to 750 RPM under load and in gear? Will spraying pre mixed fuel into the carb throats pick it back up? Choking it? Pumping the fuel primer bulb? Possible you need a carb bath/rebuild then link n sync. See the FAQ for a thread by Tashasdaddy regarding this.
