trying to get my boat going again after sitting for five years,when i installed new battery the starter just clicks, tried jumping it from yellow and red wire to battery nothing. was told engine may be "frozen" tried to manuelly turn it over from flywheel moves maybe half inch. followed that with removing spark plugs andd putting marvel mystery oil in let it sit 2 days nothing still can"t turn at flywheel. boat is in neutral i believe but lower cable broke out uf houseing near shifter link on motor prop turns freely ? eletric goes to guages and lights, radio work but nothing in rear of boat, blower, trim pump , starter, checked with volt meter 12 volts @starter, blower, pump (tried jumping up/down wire to battery nothing but clicks when i use trim switch. the ground that attached to block is corroided tried to remove but, can"t get it off, could this be the promblem? can i just change location of neg. to another spot on motor? sorry it"s a 1988 165 mercruiser alpha one fresh
> water cooled
> water cooled
