gonefishin485
- Joined
- Jun 29, 2008
- 108
ok long story, so bear with me, ill try to make it as short and painless as possible.
so i bought a 115 evinrude, no controls so im jumping the solenoid over to crank it, i took the battery that cranks my 105 chrysler with no problem, and it wouldnt spin the motor over
pulled the plugs, motor spins over fast, put even 2 plugs in, wont spin fast enough.
so i took the starter out, took it apart, cleaned it real good, put it back on, worked a little better, but still not fast enough. i put the battery charger on the battery, not quite enough, i hook it to my dodge truck, little better but still not quite enough.
so i got curious, i grabbed the battery in question, walked over to my fishing boat, 70 johnson, that i know for a fact runs perfectly fine, put the battery on it, hit the key, barely spins.
so i figured i have a shot battery, put it back on my chrysler 105, spins it over fast and cranks it right up.
i pull the battery out of my dodge truck, hook it to the 115 evinrude, spins it over faster than the other options but still not quite.
now heres my thing, how is it, this marine battery will spin over a 105 chrysler, wont spin a 70 johnny, or a 115 rude.
AND
this truck battery will crank a dodge 318 V8, but wont spin a 115 V4????
now heres whats strange, if i put the jumper cable directly to the starter post, bendix wont engage, if i touch it to the solenoid, it pops up, engages, and trys to spin the motor
the starter isnt slipping on the bendix shaft, everything has good connections, its grounded good, the choke engages when i touch the jumper to the post, all 4 coils fire a hot blue spark with the plugs out.
im stumped, anybody got any ideas??
AND
