I have searched through the threads and cannot pinpoint my problem, so now is the time to ask for help. I have a 1985 120hp Evinrude Engine
The problem is the engine boggs out at 3/4 to full speed. My question is, why? and, Could this be related to the overheat warning horn that came on?
Here is what happened;
We were at a cabin, weeklong vacation, no problems. Thurs Pm, crusing at slow speed then sped up to about 3/4 throttle, and the warning overheat horn sounds. Within 5 - 10 sec, I slow down and shut down. Removed a bunch of weeds/grass that had covered the water intake area, sat for a bit, started up with no horn and off to the cabin we went. No problems. The next day fished in the am no problems. That afternoon tubing with the kids the engine would bog down, almost like someone had cut off the fuel supply when we were at 3/4 to full throttle. Engine died, but started right up. Ran again, reached 1/2 to 3/4 throttle and it happened again. If I backed the throttle down asap it remains running but now will begin to cut out at lower speeds. If I pull back on the throttle it will remain running. But if it dies, it is harder to start. But with the warm up lever up, it will eventually start but may die when putting it in gear.
If it sits for a while starts up fine.
I thought maybe something got into a carb bowl and would get sucked into a jet at high speed, then drop out when backing off, so I have tried two thing so far. First; pulled all carb drain screws, tilted the motor and sprayed carb cleaner into bowl, just in case. Then I also ran the boat at the lake with a different fuel tank with clean fuel. Same problem occured.
Fuel related? Electrical? Did something else get damaged when the water inlet was plugged? I have a Seloc manual which has not been much help. Your help is appreciated Thanks
