Joe Reeves
- Joined
- Feb 24, 2002
- 13,262
Re: 1985 120hp bogging down at higher speeds
Since you've switched coils to no avail...... that is, the problem DID NOT follow the coil but rather stayed faulty on number one cylinder, I would assume that the spark problem is either a poor connection at one of the powerpack connectors (coil or timer base etc) OR a faulty powerpack.
The compression difference, if you're sure that the pistons and rings are okay, suspect the head gasket. Head bolt torque is 18 to 20 foot pounds, tightened in the following sequence.
9...10
5....6
1....2
4....3
8....7
9...10
5....6
1....2
4....3
8....7
