T0M BAJ0REK
- Joined
- Aug 30, 2008
- 21
OK, Ive read several threads, re this type of thing and was almost sure I would have found my answer.
Just bought a 1973 Starcraft aluminum 15 or 16 ft w/ Trailer and a nice 60 hp evinrude. I made a big stand and got the motor on there, also I reconnected the throttle/push button shifter and all seemed well.
This engine WAS winterized in 97 and though it was left uncovered, I believe it has very very few hours on it, by the look of the skeg etc.
SO,, I Hooked the harness back up, made up some good solid cables for power, and hooked it up to the battery. put it in neutral, turned the key and and ...NOTHING
Next I used the jumper cables and grounded the neg to a good solid ground and then w/ the other touched the pos wire on the starter. SHE turns over!!
The problem is, its in forward gear, and wont shift out. I NEED a wiring diagram. Though I read somewhere in here that evinrude changed their wiring from year to year etc. Could a neutral safety switch be holding me up? If so I dont see one.
In high school I took marine tech, and am omc/mercruiser certified, but that was so long ago. and I never have been up against this problem.
I am thinking that there may be solenoids in the lower unit. there are a total of 4 wires that run down there (that i can see).
Bottom line here: I sure could use a wiring diagram and cant find one anywhere on the web.
The Motor is an Evinrude 60HP Triumph model# 60173C. ( I would assume the last 2 #s represent the year 73) the serial # is 31287A.
I am in no rush. The boat needs a transom, and a floor. Needless to say I wont be out fishing this laborday weekend
can anyone help? Ill be happy to provide any more info. I am leery of what Ive read about the wiring changing from year to year.
I Intend to do this right. I would like to save the few dollars I have for any parts etc, and not blow 40 on a manual that will give me vague info about these things.
