wmgraphics
- Joined
- Jun 30, 2008
- 47
I cannot get my motor to increase in speed from the controller. I took apart the throttle assembly and found lots of old grease. I cleaned all the parts and the spring actually has a function now.
The sad part is the real problem was the timer base. I can manually move it forward to increase rpms of the motor by hand, but it feels stiff or slow like maybe this too is full of old grease or something.
Should it be like this or should it slide with ease?
My book says that the brass bushing are very close to the base and could cause a problem if dirt and stuff gets in between.
Could I spray something in or around that area to maybe loosen up the rotation of the base? If i need to remove the flywheel, what size socket do i need? Also is there a trick to do this with standardized tools, I don't have a flywheel removal tool and or holding fixture? Will my timing get messed up?
Thanks!
Thanks!
