GWDolphin25
Thread starter- Joined
- Sep 12, 2007
- 15
Hi everyone!
I'll thank everyone in advance for posting answers and questions in these posts. I find them very helpful. I am not a certified Tech so forgive me if I use incorrect terms.
I have this HPDI with a freshly rebuilt powerhead. The injectors were ultrasound cleaned and tested. Spark plugs are new. The engine oil lines were primed correctly and everything is injecting as it should.
The engine fired up and idled beautifully for about 10 minutes so I shut it off. I then got the Yamaha Diagnostic Software and plugged the motor up to the computer to see the engine monitor and run diagnostics. When I did that, the system showed everything to be normal but now the engine missed badly and I found that the #2 and #3 Cylinders were not firing. The monitor would go to YES as it cranked and did the initial fire then it would go to NO, stay at NO and miss, eventually stalling. I checked and changed the coils and cables and checked all connections and spark plugs. Everything seemed normal.
I don't know where to go with this and any help would be great. Thanks!
