50hp Johnson 'looper'
mickarch
I'm interested in a motor I found for sale on Ebay described as:
"johnson 50hp power shift 11 loop charged motor model no esl73r serial no. e3827749"
In general, would this be considered a reliable motor? Any common issues for this model that I should check for before bidding?
Can this be used with my normal gas tank, of would it need a special tank (pressurized)??
I really don't know much about evinrude/johnsons, any info would be appreciated.
Thanks,
mick
Re: 50hp Johnson 'looper'
it is an hydro-electric shift, the shift switch and the shift solenoid are no longer available. it was a great dependable motor. 1978 and up are mechanical shift and much easier to work on.
D
DJ
Guest
1973 went to hydrualic shift-NOT ELECTRIC. Hence-"Power Shift II".
It's a decent engine without the electric shift issues.
A regular fuel tank will work fine.
my mistake, sorry. they are decent motors.
mickarch
Thanks for the info. For the starting price it's listed at, I think I'll put in a bid.
kenmyfam
Find out the shipping costs ahead of winning it. An apparent bargain could end up being costly.
mickarch
Well, I went ahead and bought it and picked it up tonight. It looks pretty good. Started right up and idled well. Shifted into gear smoothly. The wiring under the cover needs a little attention, but overall pretty clean.
Can anyone help me with the year of manufacture for it? model no esl73r serial no. e3827749
Also, where I might find a repair manual and parts diagram for purchase, here on Iboats maybe?
Thanks alot,
mick
Benny1963
i boats or ebay
i have had several of tose 50s 1972 elec and 1973 hdro shift 2
once they are tuned they run great wish i would not have sold mine .
but had to much stuff around good luck bennyb
mickarch
Yeah, I'm hoping it'll be more reliable than my '66 merc 35hp and add a little pep to the boat.
So, I think I've figured out that I have a 1973 motor. I see that Iboats has the original factory service manual here:
http://www.iboats.com/Johnson_Outbo...2404666--**********.645722464--view_id.440448
I'm assuming this is the best one get? Is there another one I should be looking for, or is this the one to have?
I've found the impeller here on Iboats, but there is no fuel pump kit listed for this year/hp. Where else might I find fuel pump/carb kits?
Thanks again,
mick
Benny1963
i shop marine has good parts breakdown .
i orderd mine from local mech
kenmyfam
Good luck with it. If you picked it up then it must have been local enough to avoid shipping costs then ??
mickarch
It was about a hour and a half away... not too bad, added about $40 to the cost for the gas to get there, but all in all a good deal I think. What seems to be a good running engine for $475, not too bad.
Thanks for the well wishes, once I get the manual and a fresh impeller installed, I'll take it out and see what it can do.
