how hot is to hot??
CROWE
Volvo Penta 3.0
I went out and forgot to tighten the cap on the garden hose flush out hook up on the back of the boat(I WAS SUCKING AIR). 5min..later i iook down to see 190 on my temp. i thghten it and turn around and started back then all at once 200--225--i shut down the engine and it keep on running (diseling) my temp was 250 and i could smell rubber burning.I was towed back to the dock and went home to find my exhaust pipe connector to my riser was burn to a crisp,also my pump impeler was finnish. what other damage should i look for??
Uraijit
Banned
Re: how hot is to hot??
I'd do a compression test, to make sure you didn't warp a head, and blow a head gasket.
190 ain't so bad, but 250 is pretty scary. Water boils at 212, so you didn't have ANY water in your block. Just vapor...
Maclin
If the impeller vanes came off then you will need to back flush to get them out as they more than likely went on into the cooling system.
CROWE
I Repaired All My Damage Parts And A Few Wires.replaced My Water Pump Imepller. And Flusher Out All Ports,engine Runs Fine,temp Runs @165,but Now I Am Leaking Water From The Front Of My Sea Water Pump,what Should I Do Buy A New Pump Or Buy A Kit And Replace Bearing And Seals,i Have A Press To Press It Apart And Back Toghter But Is It Worth The Time To Rebuild. $117.00 KIT Or 300.00 NEW
It A Sherwood G9903 Pump
CROWE
It Not The Water Pump On My Block Its The One Thats Pumps Water To My Engine That Runs Off A Belt,it Mounts Off To The Side,
