jsferra1
Thread starter- Joined
- Aug 10, 2007
- 31
This week end I pulled the outdrive to repolace the Bellows, Shift Cable, U-Joints , Gimbal Bearing, Trim senders and Water pump.
It started fine and then two screws for the trim senders one on each side would not come out and yes they broke , I do the water pump no problem, I do the U-Joints no problem.
I go to take the shift cable off and BIG problem
the end that is in th bell housing the thread part brakes off in side the bell housing yes I did get the shift cable off by cutting it and pulling it out but now I have part of thread still in the bell housing.
On top of all this the Gimbel bearing looks like it has rust on it but the bellows did not have a hole in it.
I still need to get the shift cable thread out of the bell housing, So I went to try and find what size thread it is but no good, so if some one knows what size thread it is I was thinking I would be able to re-tap it.
Sorry for the long post but this week has not been fun at all , It started out ok but went south fast.
