Re: 1974 OMC Ford 302 19' New Purchase
I hadn't thought of that, of course! You might actually be right, the outdrive might be frozen, not the engine.
I've already removed the tilt quadrant and lowered the drive down. And yes you assumed correctly, the boat is on a trailer. I will separate the drive and remove the shaft and bearing from the transom.
When you say the bearing might be frozen, I assume you are referring to the bearing at the carrier around the ball gear, that you described in your post. Am I correct?
BTW, I've ordered the Seloc manual and should receive it Wednesday.
Once again, thanks for all the help so far.
