Re: 94 Evinrude 112hp still shutting down? HELP
Thanks, as soon as I can find the help I will do that. here is what I was able to do yesterday by myself. Put it in a barrel of water with 4 spark testers, 1 on each cylinder, once again strong spark on all for at idle(no suprise), so I throttled it up to around 1500 Rpm's, no higher than that, while running I took a blow dryer and heated up the power pack just to see if I had any change, no change in spark whatsoever. But here is where this gets weird. I noticed when I turned the key to the on position, my fuel gauge would jump around like it had a short, intially we thought it was the main harness to the engine, but found out it was doing it when we moved the main power line that connects to the selonoid. What is even weirder, is that we could get the gauge to work, which it should not have because the I actually removed the ground to the sending unit when I was checking it just to see if the ground was loose, removed ground and the gauge still worked??? Also noticed all of the sudden I am getting no click on the electric primer when I push the key in??? Was this boat built on a cursed Indian burial ground or something???LOL....I think I have more electrical problems that I thought, I know the sending unit has to be getting another ground, but how? Any ideas on what is going on here? The only wires connected to that tank are on the sending unit, and right now the gauge still works with no ground?
