Re: 94 Evinrude 112hp still shutting down? HELP
Also one more thing, upon further inspection I was testing out my warning horn that is hooked up to the 2 tan temp wires that come out of the 3 and 4 cylinders I believe. I disconnected the wires from the #4 cylinder, and grounded it to see I got a horn and I did, I attempted the other wire on the #3 cylinder and the connection was so badly corroded that it would not even sound the horn when grounded, I had to snip off the two leads on each connector, and put new connectors on and then I got a horn when I grounded the lead this time. I guess my question is, would something like that cause any kind of problem while running if the connection was that badly corroded? Maybe sending a false overheat warning or something?
