Re: Tilt question?
My drive just did what you describe. in a half hour i had mine working again.
Yes you can remove the motor without removing the drive.
I posted the way i do it. you want to listen to the other guy your gonna blow your motor, another 120 bucks maybe less.
You have a fully charged battery?
Remove the tilt clutch housing cover. Is there water in there? I bet there is.
Remove the clutch. How i do it i remove the the half moon gear, but first i tie up the drive, so when you remove the half moon gear it don't fall.
I remove the gear that drives the half moon gear, after the half moon gear is removed.
I remove the clutch.
I soak clutch in the strongest stuff i can get my hands on. Acertone maybe, any home depot has it, lowes, true value. Gas will do in a pinch.
Blow it dry.
Soak it in oil.
Now i use carb cleaner, or brake cleaner and spray inside the clutch housing till it's clean in there.
I reinstall the clutch, gear, half moon gear, clutch housing cover, fill with 30 weight oil.Untie the drive.
Now try it.
If it don't work than it's time to pull the motor, and it ain't a pleasure to do.
You got to be part monkey.
Good luck!
