fluidjuice
Thread starter- Joined
- Jun 12, 2008
- 54
I have a mercury classic 40 hp 1991,on a 14ft speedboat wired up a new tacho and found the rectifier needed replacing, done that and now it works , so i took it out for a spin at wot and im only getting 3000rpm's at wot.
The prop i have on is a mercury 10 inch diameter , 3 blade with a 13 inch pitch. is this over propped? and is it ok to still use? as before i was oblivious to the low rpm's. wot rpm's should be 5000-5500 as spec in manuel. i get about 30 mph at wot. tacho is registering around 650 to 700 rpm's at tickover. so if this is the prop what size is needed or standard.
I have read that by changing the pitch size up or down by one inch you can see a 300-500rpm diffrence at wot, surly my prop isnt that far out????
Thanks
Thanks
