Hi, Just boat a boat that came with a 79' 85HP Evinrude Model-85995R Serial#-J0003138.
The prop on it is junk and couldn't read any numbers off it. They used it for water skiing (boat is an 81' 15ft Glastron SSV-151). All the info I read is the prop is determined mostly by the WOT RPM range set by the Mfg. I am looking for that spec and what the recommended standard prop size would be. My use would be mostly fishing and a little please, not higher speeds (motor size is overkill but came with the boat).
Any help would be great.
Thanks, Mike
Thanks, Mike
