I need help from anyone that can tell me the basic steps in reclearcoating a boat with metal flake paint. This boat has been really abused. I have heard of a clear called imron by Dupont. Does anyone have any pointers? Thanks for any help.
It can be a little tricky to get a good repair on aged metal flake.
To get a good bond with new clear paint the surface should be sanded, the problem is if you sand into the metal flakes themselves it can make that area look different and the finished product may look blotchy. Without sanding, the clear will tend to peel or flake off after a few years, that's why it can be tricky.
Has the surface worn away down to the flake, or is the surface just chalky and dull? If it's just dull try sanding with very fine sand paper like 800 or higher, then buff. If this works then it's a much easier and lower cost fix.
I sure hope you bought personal safety protection. And I'm not talking about those cheap paper masks either.
