johnson controls
pkrainert
Do they make throttle controls for an 8hp johnson? If not is there any way to fabricate them?
Re: johnson controls
what year, model???? big question.
F_R
Go to http://shop.evinrude.com/
Click on "Electronic Parts Catalog", then select "OB Accessories" from the drop-down list where it says Evinrude. Follow through to the year and you will see what was made for your motor. It may require a remote control adapter kit. Either way, from there, the standard two-lever control should work.
pkrainert
its a 2002 pull start. The boat i have is a 72 glastron and had a 40hp evinrue. I can sort of hook up the steering but i dont feel safe. So for now i am going to use the tiller handle. I may just try to sell the 8hp and get an older 40-60 hp.
pkrainert
Do they make adapters for the controls? Also for the steering? If not I am going to try and find a 40-60 hp with controls on craigslist and sell the 2002 8hp. I hate to get rid of it but im sure the extra power and controls will be nice.
looking at the brp web site. i don't think so. contact a dealer.
pkrainert
contact them about controls or adapters?
jay_merrill
Shop.evinrude.com doesn't show an 8hp model for 2002 - are you sure of the make/year?
Also, assuming that your Glasstron is about 14' - 15' in length, an 8hp motor isn't going to be enough power for it to even plane. I think you would be better off forgetting the controls and going to a larger engine. You don't have to get rid of the 8hp motor, however. I would keep it as a "kicker."
pkrainert
Hello, I didnt think it would plane. I will be using it to troll so I dont really need to plane. Although I may be getting a 65hp evinrude through craigslist. It is a 2002 I have the manual that came with the motor when it was new. Also a parts list from when he got it serviced.
pkrainert
For some reason when i try to go to teh 2001-2004 it wont load?.?. But today I have a few people coming to look at my old boat and also my motor so if i sell both i will have a decent amount of money to put into buying an older johnson/evinrude 40-70 hp for the boat. I have a guy that wants to sell me his 65hp evinrude with controls running well for 600 dollars. So witha bit of luck I will have the glastron for less than what i paid for the 12' aluminum and motor.
i could not get either place to load the accessories.
ezeke
It is working fine for me on the catalog site, probably too busy to keep up with the traffic, so check after hours.
If I could know if its a four stroke or two stroke, I could tell you the part numbers.
pkrainert
Its a two stroke. But later today I may be trading it for a 73 Evinrude 65hp. With a recent water pump/ impeller change. I am going to buy a compression tester fist and check the compression before I trade. Anything else I should be looking for?
pkrainert
alright. He is going to bench test it for me on ear muffs also.
pkrainert
If all is well with the 73 is this a good strait across trade?
73 65 hp, depending on condition, and if controls come with it. $500-1,000.
