Re: Separating an 83 OMC stringer
First of all HW, I think the oring is in the coupler, not on the shaft. Not sure I am correct here, but I believe that ball gear wear can be as much as 25-30%. But even that is not necessary if you do not run it with the drive up. My BG's are now 33 y/o and probably do not have 5% wear on them.
For your pictures, use PhotoBucket. It is free to sign up. You do not need to use EasyShare, just upload the full sized picture from your hard drive onto PB. Below the upload box you can choose the picture size. Choose the 640 x 480 setting. Once you select it, it will stay that way and you will produce pictures that are the appropriate size for the iboats screens.
http://photobucket.com/
Once you have your picture on PB, you click on the little yellow box(here on iboats) with the mountains on it and paste the url link to your picture.
I'm not familiar with your camera but it should have a Macro setting. This allows you to take pictures close up that are below the normal focus distance of the camera. Here is a cut and paste off the website for your camera.
Focus range
normal wide: 1.6 ft (0.5 m)?infinity
normal tele: 3.9 ft (1.2 m)?infinity
macro wide: 4.7 in.?2 ft (12?60 cm)
macro tele: 2?4.3 ft (60 cm?1.3 m)
