Bravo question
daviscfad
I was wondering if anyone knew any good websites on where to buy a bravo transom assembly and bravo 1,2, or 3 drive Thanks for the responses
daviscfad
Re: Bravo question
okay i bought a new transom assembly bravo that is... When i do my upgrade from an alpha is my hole have to be bigger? I havent got the unit in just trying to set my self up mentally for what i have to do
achris
More fish than mountain goat
Re: Bravo question
What year was the unit you removed? Some Alpha holes are already right for a Bravo, some need a couple of holes drilled at the top and the earlier ones need quite a bit of rework...
Chris........
daviscfad
Re: Bravo question
i am not sure which year it was it was on theboat when i got it but i know it was not on it originally i would say it was a 2002 model or so.. i know i will have to drill the top to wholes but j/w if i had make hole bigger or not?
achris
Re: Bravo question
IF the previous engine was an Alpha 2002, then the Bravo should bolt straight in...
daviscfad
Re: Bravo question
ok thanks achris.... ok last question... I know it bolts on butdo i need to add 5200 to it???
achris
Re: Bravo question
ok thanks achris.... ok last question... I know it bolts on but do i need to add 5200 to it???
Depends on the engine, usually 4800 is enough.. My engine does 5100 with the 17" prop and 4800 with a 19" prop....
Re: Bravo question
Nope,...
It should seal Just Fine with a new gasket,+ a Clean Smooth surface....
Don S
Re: Bravo question
You do realize you will also need the inner transom plate and exhaust Y don't you?????
Uhhh Chris, I think he was talking about this 5200 ;) :p
hardwoodint_2024_16894023
daviscfad
Re: Bravo question
It come with the inner transom plate what do you mean exaust?
daviscfad
Re: Bravo question
yeah its complete with everything i was just wondering what risers he was talking about
daviscfad
Re: Bravo question
HT32BSX115
1987 Four Winns 211 Liberator powered by a
1997 Mercruiser 454/Bravo III
I have the same boat!!! You have a picture of your i can see
HT32BSX115
Re: Bravo question
Well....yeah. I do!
I haven't posted those pictures in a few days:rolleyes: I'm getting pretty good at it.....
So, here goes!
Before
After
Cheers,
Rick
