Alright, here's the set up. My wife and I unveiled our restored Thompson Lake TVT runabout at the Toledo Boat show August of this year. A fellow came up and offered to sell me two 1956 30HP Johnsons, all the repair manuals, and a custom built steel rack on casters. I chuckled, but curiosity got the better of me. I called the guy and went to see the motors, which looked like they were 52 year old Johnsons. Paint in bad shape, etc.
Then he offered them to me for 200.00 bucks all-in. I said "I'll be back from the ATM in a few minutes."
I've already asked about one of these motors that turned out to be a Johnson Javelin. I've found the missing trim pieces and the motor is safely stripped down with all the parts in separate zip-lock bags, in carboard boxes until the larger components get back from being blasted, cleaned, primed, and painted.
Today I started looking at the other '56, cleaned the rat crap and bug nests out. It is missing a faceplate, the high and low speed knobs, but everything else is okay. Then I pulled the plugs to check compression. Seems fine.
I was told the motor was seized, but came to find out that the recoil had jammed with the flywheel somehow. I removed the recoil to check the ignition parts, and they will need to be replaced. No big deal.
Also this is not an electric start...but rather an RD18-C I believe. (OH...my aching back!?!?)
I've had so much fun working on the Javelin, I'm wondering if I should bother with this motor and do a full restoration, mechanical and cosmetic. Should I do somthing in between? Do I even bother.
I also have my little old failthful Seahorse 18 FDE-11 that I've been using, but I can't see owning 3 motors.
Would it be worth it to keep the other 30hp? I just really am intrigued by working on these old beasts and learning about how they work. (Not something I'd have ever thought would strike my fancy!
Is this the beginning of an illness? I've enjoyed trying to hunt down the parts on the auction site or other classified ads. Being able to bring these relics back from the junk-pile is a hoot!
Your thoughts? Restore it, sell it, or junk it?
Thanks!
Greg
Thanks!
Greg
