Re: new deck & stringers, man this sucks
well I did the core samples an the transome tonight...guess what???? thats right it needs to be replaced... what a shocker right...
I got to looking at it, and in oops! boat he bonded two pices of wood together and they go all the way across the back of the boat. In mine i have 1 pice of 3/4 that goes all the way across the back, then another pice of 3/4 that starts about 1.5 ft. in from both sides, than a 1/4 in that is about 6in in from the last one. Then they are all 3 glassed over with what it looks like CSM. Why would they have built this transom like this???
I wanted to know if i can take 2, 3/4 and 1, 1/4, and take it from one side to the other. all the same thickness, a total of 1 3/4in. all the way across??? and also glass them together and in, with the CSM, or should I use something else??
i know this is a dumb question, but here i go anyways.
I have a new 4.3l I am putting in the boat. It has a OMC Cobra outdrive hanging off the back and i would like to keep it. I do not have the money to put a newer up-to-date drive on it now. I dont know when I will. So I have to put the Cobra back on! But, in the future, how hard would it be to update the drive?? I know i will prob. need to put a different transom in it then, and fill the hole and get the new drive to fit. Is it even possable to put a diff. drive on this boat??
I am only 27, and this id the first boat I ever owned. I would like to get this boat out on the water this spring so we have something to do.
Well, just let me know what you think about the transom.
Thanks for all the help you can give guys Bryan
