coolguy147
- Joined
- Jul 14, 2008
- 2,817
well im not sure what to do. i think i might have added to much oil in my gas tank would this cause the miss or lean sneeze? well i had this 1 gallon tank with with some 50 to 1 mix in it for my tiller. i put about 5 ounces of outboard oil to be sade cause i wasnt sure if they were different oils. then put some left ovr stabilizer not much and started the motor. it was hard start on last friday about 50-60 degrees out i think it was 13-14 pulls. before the fill up by the way. all i did was add 2 gallons with 1 pint of oil to the already mixed gas on friday. then i took the leftovr gas from tiller added oil and put that in the tank today. took even longer to start and it was coughing for soemthing like a jerk. i noticed it did the same thing on friday but after it warmed up it stopped. it just kept coughing all day and i couldnt get it to idle like it was on friday. i did a quick readjustment of the needles again and it helped some but still did some. i noticed when evr i adjust the needles the low speed needle is out about 1 and a half turns then i turn it in abotu 1/8 of a turn any more it will cough like crazy this normal? but after the adjustemnt it helped some. i checked the spark plugs and the bottom one seemed more oily then the topwould be caused by gravity? more oil or gas to the bottom cylinder? i noticed that if i pulled even one plug out on both it wouldnt even start. lol didnt wanna try to pull the cord out while it was running i had a bad experiencel lol zzz shocker. only problems i could see would be dirty carb bad spark to much oil. i do notice some but few sediments of rust in the bowl it might be time to get a filter but i dont know if this motor had one?
