Re: OMC Cobra and Delco EST Ignition
Now that I know this can work, I am excited now. I am going to replace the whole distributor. Delco sells a complete marine kit with distributor, wiring harness, coil, and plug wires. Yes docs are stingy and I like to save money but I like to do things right. I do have a manual. I am replacing the distributor because the shaft has a lot of free play, bearings/bushings are worn out. In addition, I accidentally kicked it off the swim platform and as luck would have it, it landed on the gear and did some damage. The mechanical advance inside has a broken spring with another one about ready to go. Other than that it is in perfect condition! I am building putting a new motor in and can't see trying to salvage the distributor in the shape it is in. I can't wait to see how this works. Thanks
