Wellcraft Excel 1992 18sx
Status
Not open for further replies.
Robj
Re: Wellcraft Excel 1992 18sx
oh.....
i was misunderstanding as you said before that you used feeler gauges which are very thin...so i thought you had to get the shield 2m away from the fly wheel housing.
so the 2 mm or 1/16 of an inch is not the distance between the shield and fly wheel housing... its the allowed variance between the 3 tabs distance between the shield and transom?
Correct. To the best of my knowledge. I just used feeler gauges, sometimes 4 or 5 on top of each other to measure the gap to make sure the variance is no more than 2 mm, of course no variance is probably the best.
Have a great day
Rob.
PFalcon
Excellent Build!
Amazing (to me) speed, and capability!
Keep it up, looking great! Considering finding one of the hulls in the area after seeing yours and Rob's
PF
92excel
Hey Rob, thanks for the clarification.. did you get your boat back? i would like to see pics of the cover you got made!
PFalcon.. thanks for checking it out.. more updates soon.
bear_69cuda
Hurray the Volvo is in!
You rule!
Can't wait to see the rear seats... You doing a sundeck/bench?
Great progress!
92excel
Going back with what was there.. two jumps seats, one on each side of the doghouse.. hoping to get done soon!
92excel
Got a lot of work done since the last update.
I build the hatch to my ski locker. It is soaking up some resin and will get csm and cloth to match the deck.
I painted the bow storage areas with a rustoleum white. I am thinking about carpeting this area so things in there wont slide all around..
92excel
I built the middle section of the stern seating area which will be removable to allow easier access to the engine. the pic is a little blury.. too many pops :p
And a shot with the dog house.. I still need to clean up the doghouse cover
92excel
I finished up most of the stern area seating. This was all tabbed in and ready to be painted. I still need to add some extra supports for the seats.
a reminder of what was there before:
jcsercsa
That looks great there justin !!! keep it up !!! John
92excel
thanks john!
I have to clean up the garage and might get to painting the deck this weekend.. depends on weather. I chose Interlux interdeck off white.
upholstery should be ready to be picked up this weekend as well.. atleast i hope so.. i have heard it would be ready for the past two weeks.. :(
PFalcon
Suggestion if you don't want things to slide instead of Carpet which will absorb and hold water everywhere, I would suggest you do as I have done:
Buy the Rubbermaid(Tm) rubber shelf liner, you can cut it to fit, get in any many colors, then stick it down with some regular contact cement or even the 3M(Tm) Spray on Contact Cement.
The Rubber shelf liner holds everything, except water, even a strip on the top of your cockpit/console areas will keep things like cellphones, "pop" etc from sliding around. I even put it in the bottom of my F/G drink holders.
PF
92excel
not a bad idea... i agree with carpet holding water..
ill have to get some and see how it looks.. thanks!
92excel
This weekend i was going to try start painting the deck, but decided to get the engine taken care of.
I applied two coats of paint the the stern area storage compartments.
The Stern Drive was put on and i replaced both bellows. The engine is all aligned and bolted into place. I hooked up all the wiring and installed the battery box and battery.
92excel
Tonight i got to painting the deck. I got the primer coat on. I used Interlux Pre Kote
about half way there..
all done for the primer
92excel
The sides of the hull will get carpet. a smoke grey from Cabela 's
I will also be installing storage pocket along the hull deck seem. This will hide the seam of the carpet.
92excel
Last night I got the second coat on. The seating are sides are smooth and the deck got grit for the anti slip. It is looking pretty good..
I dont know why this pic looks purple but it is off white color paint
92excel
I am going to go with one more coat probably this evening. That will give me one primer and two finish coats.. its covering real well.. Any reason to add a third coat?
jcsercsa
Looking good there Justin !!! if she covered with the two you should be good !!!!!!! whats next ??? john
92excel
Next... Install the carpet on the hull side, install the interior, install the radio and speakers, buff and wax and inspect and service the trailer. Then hit the water!! getting CLOSE!
Status
