Kenny1970
- Joined
- Sep 21, 2007
- 60
Hello all I have a pull start Evinrude that has weak spark on the upper plug. The bottom will spark good and when I hold the plug and ground my self to the block I get shocked and the upper on will not shock me holding the plug.I swaped the plugs thanking they were bad but the same thing happens.If I put a screw driver in the uper plug wire I get shocked.
It just will not go through the plug. I pulled the fly wheel and cleaned the points and every thing looks good.
Before I replace every thing could some one that knows about these old outboards tell me if they ever had this problem before and what they did to fix it.
Also do they make a kit to do away with the points?
Thanks Kenny
Thanks Kenny
